by Joshrobbo Investigator
Can you get a signal booster? I get dreadful coverage at home!
Read more
7 REPLIES 7
Re: Can you get a signal booster? I get dreadful coverage at home!
Hi @Joshrobbo
Can your device not connect to EE VOWIF service?
Good Morning @Joshrobbo.
Have you been able to follow @Northerner's advice and connect to WiFi Calling?
What phone are you using?
Jon
Unfortunately I have no WiFi..
Thanks for getting back to me @Joshrobbo.
A signal booster would run off a WiFi connection too so I'm afraid that wouldn't work.
Have you checked our Network Status Checker to see if there are any issues in your area?
Jon
by Profile closed
Not applicable
@Jon_K A signal box doesn't use WiFi, it plugs into a broadband router using a Ethernet cable so whilst a broadband connection running at >2Mbps is required, WiFi is not required.
Thanks @Profile closed.
My wording should have been more specific.
I just assumed that because there was no WiFi, a broadband connection also wasn't accessible.
I could be wrong!
Jon
Do you have any Broadband at home? A Signal Box only works with Home BB.
