by burrows1980 Investigator
Can’t view/send pictures WhatsApp on mobile data?
i have the same issue with Facebook and Twitter, can’t load content when on mobile data only works on WiFi.  I’ve reset network connections, updated all apps, on current iOS delete app reinstalled, made sure it’s on WiFi and cellular data in the apps etc......
It only started doing it over last few days, everything else works fine on mobile data.
I can’t even load WhatsApp website on safari when on mobile data, any ideas?
Gaz
Re: Can’t view/send pictures WhatsApp on mobile data?
Hi @burrows1980
Make sure content lock on your MyEE app is set to off. If it's set to off set it to strict, restart , set it to off restart.
Hopefully that should fix the problem.
Hi @burrows1980.
Welcome to the community.
Let us know how you get on following @Northerner's advice.
Jon
