by Katie7 Investigator
Can't sign into ee network
Hi, I'm pay as you go. I keep getting a message saying sign into ee network when I try to use mobile data. All works fine when connected to WiFi but I have 1gb of data to use still that I can't seem to use. Any help?
Thanks!
7 REPLIES 7
Re: Can't sign into ee network
@Katie7  What device is it ?  And have you allowed the apps to use cellular data ?
It's a Sony Xperia z3 compact. Yeah, apps all set to use cellular
Hello there @Katie7
Thanks for coming here.
If you click on this link http://add-on.ee.co.uk/
What allowance does this show?
Thanks 🙂
Hi, if I click on that link it says unlimited data allowance...
Hi @Katie7,
What happens when you try to load a webpage with WiFi turned off?
Just says site cannot be reached
Hi @Katie7,
Do you have this problem everywhere or just in one location?
Is this a new phone? Have you used it on the EE network before?
