by Briansigns Investigator
Can't connect mobile router to smart tv
Tried a few times but every time it says it's connected  you try and go to an app it you have no internet connection
Re: Can't connect mobile router to smart tv
@Briansigns   It might be connected but is there any data allowance on the router to allow a data connection?
Hi @Briansigns.
Welcome to the community.
Does the router work and give you data on other devices apart from the TV?
Jon
Yes 2 mobiles and a tablet no problem....
But it did come with the minimum amount of data...I think £10 worth could that be the problem..
Thanks @Briansigns.
As long as you've got data to use, it doesn't matter how much you've got. Is there definitely some data left?
Have you checked the postcode to see if there are any problems in our Network status Checker?
Jon
