by zerostate Investigator
Can't buy more data
I'm on PAYG and buy more data when the data runs out. But now I appear unable to do so.
It appears that the add-on.ee.co.uk website won't load because I have no data on 4G and when on wi-fi it says I need to be connected via 4G.
This never used to be a problem, but appears to be now.
Looks like a sneaky way to push PAYG customers over to contracts.
Solution
Re: Can't buy more data
Turning the phone off and on again seems to fix the problem.
Solution
by Ace Contributor
HI, @zerostate
You don't need data to open http://add-on.ee.co.uk/purchase
Page make sure your mobile data on when you open this link.
Restart your phone and try again.
Hi @zerostate
I'm glad you're all sorted. 🙂
Give us a shout if you ever need some help.
Chris 🙂
