by Teufelkoch74
Can i upgrade to unlimited data on my phone and how much would it be?
by Profile closed
Not applicable
Solution
Re: Can i upgrade to unlimited data on my phone and how much would it be?
Hello @Teufelkoch74 unlimited data allowances are not available on EE PAYM or PAYG. 🙂
7 REPLIES 7
by Profile closed
Not applicable
Solution
by Teufelkoch74
Shame. But thanks for the quick reply!!!!
by Profile closed
Not applicable
You are welcome @Teufelkoch74 come back to the community anytime if there is anything else you would like to know. 🙂
by mdwh Contributor
Well, unless you're downloading from Apple music then it's unlimited, limited from everyone else, because so much for net neutrality.
by Brilliant Contributor
@mdwh wrote:
Well, unless you're downloading from Apple then it's unlimited, limited from everyone else, because so much for net neutrality.
What you talking about?
Apple or Android don't get any sort of unlimited. Your data goes by your plan not your phone.
by mdwh Contributor
I mean data downloaded from Apple music - nothing to do with what kind of device you have. (One doesn't download "from Android".)
Data downloaded from Apple music is o my for the 6 month promotion they are giving out. It's not forever.
And Android can use this offer as well.
