by Hibbariz
New Member
Can I use my phone in Europe ??
by Ace Contributor
Re: Can I use my phone in Europe ??
Hi @Hibbariz yes, you can use your phone is EU (allowance )  without any extra cost and up to 15GB data.
Hi @Hibbariz
To add to @tahirmian  comments, make sure roaming is activated by texting ROAMING to 150.
To activate roaming manually:
Log into your on line account and then Menu - Manage Device - make sure you have activated roaming and international calls.
Or
From the MyEE app Current Usage - Controls - activate use phone abroad and make international and premium calls
