by Nikki8279
Can I use my ee data as a hotspot?
How do I turn my phone into a hotspot using my data allowance? Can I invite anyone to use it if I want, even if they are with a different provider?
Re: Can I use my ee data as a hotspot?
Hi @Nikki8279
Yes to both your questions.
As to where to find it, it's normally under network, but you haven't said which device you have.
by Profile closed
Not applicable
Yes, all EE plans allow tethering.  Any data used whilst tethering just comes out of your monthly data allowance.
You need to enable this in your handset’s settings and then connect the other device to your handset like any other WiFi device.
Hello there @Nikki8279
I can see you have had some great advice already 🙂
Full information on how to set up your phone as a personal hot spot can be found on the How to tether Help page.
Let us know if you need anything further.
