by Mollie5
New Member
Can I use my data in Turkey
by Ace Contributor
Solution
Re: Can I use my data in Turkey
Hi @Mollie5
Welcome to the EE Community,
unfortunately as Turkey is not a member of the EU you can't use your inclusive allowance while in Turkey you can buy additional bundles to help lower the cost of roaming there they can be found here.
https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/turkey...
If your a Pay Monthly customer text ROAMING to 150 before leaving the UK to make sure your account is enabled.
Thanks,
David.
by Ace Contributor
Solution
Hi @Mollie5
Thanks,
David.
