Highlighted
Can I use my data in Canada
When I go to Canada can I use my data?
6 REPLIES 6
Highlighted
by Brilliant Contributor
Re: Can I use my data in Canada
Depends what plan you have?
You can still use it but it may not you quite a but more if you are not in the Max plan.
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.1)
Highlighted
by Ace Contributor
Worth checking out the roam further add-on, if you qualify for it.
Highlighted
Good Morning @Elloellie
Welcome to the community.
I can see you have been provided some great advice already, please let me know if you have any further questions.
Katie 🙂
Highlighted
Are you on contract or PAYG? If on contract, do you have an EE Max Plan? If so, you may use your data up to 15GB per billing month if you have more.
If you are on contract, remember to text ROAMING to 150 before you leave to check roaming is enabled on your account.
Highlighted
I have a contract but it’s only 1gb, so do you think I can use data without it costing more?
Highlighted
No, not unless you have a Max plan. Otherwise you will need to buy a roaming data add-on as in https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/canada .
