Highlighted
New Member
Can I use my data abroad
I have a p20 and it says on the app that my text and calls are unlimited in the EU but dosnt say anything about data? I'm going away soon can anyone help
Highlighted
by Brilliant Contributor
Re: Can I use my data abroad
Hello @Mcox04 ,
Welcome to the community,
I would suggest you take a look here to make sure your phone is ready for use when roaming:
https://community.ee.co.uk/t5/Roaming/EE-Roaming-Getting-ready-to-use-your-phone-abroad/td-p/749932
Highlighted
Hello @Mcox04
Thanks for coming here for help 🙂
You can use up to 15GB of your data when Roaming in Europe 🙂
If you can make sure you are set up to use your phone abroad before you go following @Schockwave advice 🙂
