by eviep12 Investigator
Can I use my 4G data allowance abroad in the EU?
by Brilliant Contributor
Solution
Re: Can I use my 4G data allowance abroad in the EU?
Hi @eviep12 Yes you can use data and minutes and texts abroad in the Eu without charge there is a fair usage policy of 15gb for data each month when roaming in Eu
Please text roaming to 150 before you leave to make sure you are all set up
6 REPLIES 6
Solution
@eviep12  You most  certainly can and your calls/text allowance.  You can use up to 15GB of data if your tariff has this or more per month while abroad.  For a maximum of 60 days in any 120 day window,  Make sure you text ROAMING to 150 before you leave the UK,  you can do this now if you wish,
Ok thank you
@eviep12 Your most welcome have a great time
Thank you
Hi @eviep12,
Welcome to the EE Community.
I can see you have already had some great answers from the community. Smiley Happy
If you need any further information, please see EE Roaming - Using your allowance abroad.
