by Ellen_symon
New Member
Can I be sent more data
Hi I’m just wondering if it was possible for EE to maybe swap texts for data?
Solution
Re: Can I be sent more data
Hi @Ellen_symon
No that's not possible.
You would need to upgrade your tariff for more data. Give EE CS a call to establish what they can offer you.
Solution
Hi @Ellen_symon
