by D11nts
Can I Use my data in the USA
by Ace Contributor
Re: Can I Use my data in the USA
If you have a Pay Monthly or a sim only contract, then you can purchase the roam further add-on to use part of you allowance in the USA.
https://ee.co.uk/help/help-new/offers-and-services/passes/what-is-the-roam-further-pass
W
Hello @D11nts
If you're on a pay monthly Max plan started after 10 May 2017, or have the Roam Further Swappable, you can use your calls and texts, as well as up to 15GB of your data allowance, you can add the Roam Further pass for £10.00 a month.
For any other plans, you can check out our available add-ons and prices on our roaming tool.
Make sure your roaming is set up before you go too. You can do this in your My EE account or by texting ROAMING to 150.
Recent solutions
