by Ant202
CCTV Not accessible
On an iPhone 11 how do you solve the problem of not being able to view cctv over internet on the EE network?
Re: CCTV Not accessible
@Ant202  You could try using a VPN and you probably need to ask the CCTV manufacturer to update there end so it can use IPV4.
Hi @Ant202
Are you connecting over ipv6 or 4?
Can you connect over WiFi?
by Ant202
Hi don’t know what ipv6 is? Yes can view over WiFi only
Sent from Anthony's I-pad
@Ant202 : You probably can't if you are trying to view a CCTV running on a home BB network from a mobile running on EE's mobile network.
It is possible that you are up against a limitation of EE's mobile network. The EE mobile network uses Carrier Grade NAT (CGNAT), which means that you don't get your own public IP address but share it with other users. So you can't be uniquely id'ed on the Net & therefore your LAN cannot be addressed from outside for unsolicited accesses. This is unlike fixed BB.
