by DanielJP92
Business iPad with Mobile data won’t access the internet
I received an iPad for some work that I’m having to do abroad that has an EE SIM card so that I can use mobile data but it won’t access the internet using it. I don’t know why it won’t work.
Re: Business iPad with Mobile data won’t access the internet
If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't need to & can't do any of the above.
