Highlighted
New Member
Bt sport id
Hi I have texted 150 to get the bt sport trial. It says that the trial is active in my account. I cannot find the bt ID anywhere though, I need this to login on the bt website. I activated the trial several days ago. Anyone help with this? Cheers.
Highlighted
by Expert Contributor
Expert Contributor
Solution
Re: Bt sport id
Your BT ID will be your e-mail address. If you haven't activated it via a link, go to the following site and enter your details:
www.bt.com/eesport
Highlighted
Expert Contributor
Solution
Re: Bt sport id
www.bt.com/eesport
