by XsamlsX
New Member
Blocker on my 4g
My 4G won’t allow me to view websites for lingerie or anything of that sort and I don’t know how to undo it
Solution
Re: Blocker on my 4g
Hi @XsamlsX
Try removing content lock.
Try logging into your MyEE app then - Settings - Content Lock - change this to off. Then restart your device.
It should now work.
Thanks,
Solution
Hi @XsamlsX
It should now work.
Thanks,
