by Nico_S Valued Contributor
Valued Contributor
Birmingham B1 data running at 0.8Mb/s
According to the status checker, there are no problems in this area, but several speed checks are showing 4G data download speeds under 1Mb/s.
EE please investigate.
by Star Contributor
Star Contributor
Re: Birmingham B1 data running at 0.8Mb/s
Have you got a more accurate location ie Full postcode and I'll look up later?
Hi there @Nico_S
If you're experiencing issues but the EE Network Status Checker isn't showing a problem in your area, you can report this using the ‘Report A Problem’ button.
  • Enter your postcode and tap the ‘Report A Problem’ button.
  • You will be asked for further information around your problem so we can do some further investigation.
  • We will get back to you within 48 hours with an update.
Thanks, Leanne.
Valued Contributor
Thanks, B1 3HN
by Star Contributor
Star Contributor
There's a site NE of you on 'The Big Peg' which is Band 3+7+7 although you are roughly between its sectors and B7 will be outdoor only at the given postcode. One of the sites SW looks to only have B3 at the moment but antennas suggest an upgrade is in plan.
Valued Contributor
Thanks, although it's not a location issue generally. I'm used to seeing 70Mb/s download and 40 Mb/s upload.
It's now at 11Mb/s download, so better but still not running at it's usual fast speed.
