by AspiA Established Contributor
Approx how much data would I use watching a film on prime video
Approx how much data would I use watching a 1 hr film on prime video?
Re: Approx how much data would I use watching a film on prime video
Hi @AspiA
It depends on the quality of the stream you are watching. If you have the EE video data pass swappable it won't use any data.
Hi @AspiA
Without the Video Data pass swappable that @Northerner mentioned, approximately 180 - 240MB per hour on standard definition and 240 - 360MB per hour in high definition.
Check out our how much data am I using article for more information on managing your data. 🙂
Recent solutions
