by Em03
Apn setting
Yesterday I activated my New SIM card. I have a doogee x70 and my SIM card does not working. No internet, no phone, no sms please help
Re: Apn setting
@Em03 :
  1. Just manually search for EE as your Network Operator & it should auto set up your APN.
  2. You could just go to the online tool and download them to your phone.
  3. Look them up in
    EE APN Settings: Where to find them .
Re: Apn setting
@Em03
just looking at the connection type that device supports and you’ll only get 2G with EE.  The device doesn’t support 4G and the device will not pick up EEs 3G network.     The device is not really compatible with EE network.
Please read THIS and look at the GSM and mobile network.
these are the EE bands and what they used for.
  • 800MHz(band 26) for 4G
  • 1800MHz(band 3) for 2G and 4G
  • 2100MHz(band 1) for 3G only
  • 2600MHz(band 7) for 4G
by Em03
tried Re: Apn setting
I tried the Android setting but did not work other option?
Re: tried Re: Apn setting
@Em03   The best option is to change network to a network that supports the device and the bandwidths it has,  or purchased a device that can be used on EE.  That device is not compatible with EE as you’ll only pickup a 2G signal.
Recent solutions
