by shanclan Contributor
Antenna cable extension - what spec?
I have an external antenna fitted by EE and I am moving my router.  Looks like I will be a couple of metres short for the new position.  The SMA extension cable I ordered looks a lot lighter than the cable already fitted and I want to avoid any loss if possible.   What spec should I have ordered?
Re: Antenna cable extension - what spec?
Hi @shanclan
Welcome to the community. 🙂
Installations are handled by a company called TSG. Our Tech Gurus will be able to help you get in touch with them.
Just to close this out, the thinner cable was RG174 spec. 3m extension worked fine with no loss in performance.
Recent solutions
