by John1v6_AGAIN Investigator
Am I right in assuming that voLTE is only available on handsets with EE firmware
My handset is an LG G5 which on the face of it is voLTE capable. Since it was supplied by LG it obviously doesn't have EE firmware which presumably means no voLTE?
Is this correct? (Flashing the handset to EE firmware is not an option for various technical reasons).
Solution
Re: Am I right in assuming that voLTE is only available on handsets with EE firm
Hello there @John1v6_AGAIN
Thanks for posting again.
The LG G5 would need to be purchased direct with EE for the 4G Calling to work.
Full information can be found on our 4G Calling support article>
Thanks, Leanne 🙂
6 REPLIES 6
That is correct. You need EE firmware (unless you have an iPhone).
Solution
Thanks, Leanne 🙂
by Ace Contributor
There are other phones you can buy elsewhere and VoLTE will work. There's a list of them here.
http://ee.co.uk/help/phones-and-device/4g-calling
So it's not just the iPhone that you can buy from anywhere.
Currently the list is:
  • Apple iPhone 6, 6 Plus, 6S, 6S Plus, SE, 7 or 7 Plus
  • Google Pixel, Pixel XL
  • Huawei P10, P10 Lite, P10 Plus
  • HTC U11
  • BlackBerry Dtek 60, Dtek 50, KEYone, Priv
  • Nokia 3, 5
Thanks for helping @chistery.
Thanks for all the information - most useful.
I shall not be changing my handset for the sake of this feature (especially since I have only just changed it).
Can't be bothered going down the rooting/flashing route either (too much hassle)
Its not a make or break feature for me I was just curious.
PS: In my experience I have found indoor 4G/call coverage on EE pretty good wherever I have been.
Thanks for the feedback @John1v6_AGAIN
Let us know if you need anything further 🙂
