by Ttupa10 Investigator
Add on worked in London, won't work in Prague
As the title states, I was successfully using my add on in London for a few days. Now that I've moved on to Prague in my trip I can't seem to figure out how to make it work.
I was was under the impression that Prague was covered under the service.
Once i arrived in Prague my carrier changed from EE to T-mobile. I'm not sure how to fix it. Any suggestions?
10 REPLIES 10
Re: Add on worked in London, won't work in Prague
What add-on?
The 4G EE 5GB data add on.
Hello there @Ttupa10
Thanks for posting on the community.
What happens when you try and use data?
Can you make calls and send texts?
Also, are you with us on pay as you go or pay monthly?
Thanks, Leanne.
When I try to use data it just says I'm not connected to the network.
I'm currently on wifi trying to figure it out.
My add add on is only for data, so I've refrained from calling and texting.
If you were on contract, you'd have an allowance that included texts that you could use in the EU, nevermind the add-on.
So are you on contract or PAYG?
Hi @Ttupa10
Thanks for coming back to me.
What phone are you using?
Also, are you pay as you go or pay monthly?
Speak soon, Leanne 🙂
I'm not on contract. It's pay as you go pre loaded with 5GB. I have only used 1gb so far and it's only been a few days.
Thanks @Ttupa10
Can you try and manually select a different network available in Prague,
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Let us know how you get on 🙂
I'm using an IPhone 5s with a pay as you go plan.
Hi @Ttupa10
Let me know how you get on 🙂
