Highlighted
Activate data iPhone x
I recently purchased an EE SIM card (3 days ago) upon my arrival to the UK and loaded into my unlocked iPhone X. I travel frequently and often switch SIM cards without any issues.
The pay as you go package. included calling, sms and data bundle. Calling and sms work without problems, but data does not work. I tried resetting network settings, but still no success. Any ideas other than resetting network settings?
Highlighted
Solution
Re: Activate data iPhone x
@Nmatatu  Could you please go to Settings>General>Profile and make sure your network provider hasn’t installed a profile on your device,  if there is one you’ll need to delete it for the data to work with your EE sim. When you put your network SIM card back in the device the profile will be reinstalled.
Highlighted
Solution
Highlighted
by Profile closed
Not applicable
@Nmatatu With WiFi turned off, try browsing to http://add-on.ee.co.uk/status on your iPhone and follow any instructions (it should still let you connect to that page).
