by Andrew3113
Accurate data usage
With my plan I get 5gb of data, resetting on the 11th of every month.
According to the EE app I still have 4.4gb of data left until the 11th.
However according to my phone I have used 3.42gb of data so far.
Does anyone know why there is such a big difference and how do I get an accurate usage total?
by Ace Contributor
Re: Accurate data usage
Some time in app you get wrong data usege information try to restart your phone and check again.
also you can check this at this link add-on.ee.co.uk or texting al to 150
by Andrew3113
Thanks for the reply.
I have restarted my phone but there is no change in what the app or the phone is telling me I have used.
I also texted AL to 150 and that says I have 4.4gb remaining
by Ace Contributor
it might be some glitech with your account try after few hours it will be fine
Hello there @Andrew3113.
Welcome to the community.
If you tap on this link http://add-on.ee.co.uk/
This will show you how much data you have left.
You will need to turn off WiFi if you are connected first 🙂
Hope this helps!
@Andrew3113   Your device is not going to be accurate and I would never go with what my device tells me.
