by JJessamine
Access my data plan in USA
My data plan should allow me assess to all my data, the same services levels abroad as in UK. The system isn’t working, not letting me access my data, I have had to buy add on data just to get by..
Can’t contact my EE as website down?
by JJessamine
Solution
Re: Access my data plan in USA
I had 4G Max plan, with available data.
Got through to customer service on live-chat, explained. Got transferred to tech department. They all agreed that the data was there but I couldn’t access it. So they performed a reset. Plus asked me to.
Settings-General- Reset- Reset Network Settings
it worked after this and I was able to access my uk data plan.
Thanks for for caring and sharing on the community.
@JJessamine  login to your online account and you can chat to customer services via live chat.
just to check you say data plan do you mean a SIM card that’s in a tablet?
Hi @JJessamine,
Thanks for visiting the EE Community.
Which plan are you using?
by JJessamine
Solution
No problem @JJessamine Smiley Happy
I'm happy to hear it's sorted.
Enjoy your time in the USA.
