by Elvissa31 Investigator
APN settings
How do I request the EE APN settings via text message thanks
Solution
Re: APN settings
8 REPLIES 8
Solution
Re: APN settings
Re: APN settings
It’s going to the unlock your handset page new EE pay as you go sim card is registered but and has a pack for calls texts and data but the internet is not working there are no data settings the sim is in a q80 kids smart watch and needs data to work for parent tracking
Re: APN settings
Re: APN settings
Hi @Elvissa31
Welcome to the community.
Did you manage to get sorted using the link that @Chris_B posted?
Re: APN settings
No unfortunately I haven’t I’m really not good with these sort of things can’t EE just text the settings to my mobile number that would be so much easier 😀
Re: APN settings
Thanks Chris still can’t do it not good at these sort of things wish EE could just text me the settings as other networks do
Re: APN settings
Hello there @Elvissa31
If you can give us a call our customer service team will be able to look into this for you.
Let me know how you get on.
by 19DjH79 Contributor
Re: APN settings
