by Joshnazarenko
New Member
APN settings blocked
Hi, it's my first time posting on here and we'll this is kind of like a last resort as I have tried everything to sort out my ee sim card as I can text and call people perfectly but when it comes to using my mobile data I can't and I have done everything to try and get it to work as I even discovered yesterday I was blocked out of making any apn's to sort it out which most likely would have sorted the whole problem out as I kept getting some sort of error message Everytime I went to save an apn as it didn't even save as it kept saying 'access point name settings are not available for this user' and this is on my htc M9 I am currently using and an ee sim card has been working perfectly fine in it ever since I got it as originally it was a 3 phone and when i tried loads of different sim cards in it yesterday the 3 one was the only one that worked and also let me access the apn settings but I don't want to have to use a 3 sim card as I have credit still topped up on my ee one, if anyone has a solution to this problem could you please post would be very appreciated
by Profile closed
Not applicable
Re: APN settings blocked
Hello @Joshnazarenko can you create a new EE profile when the 3 SIM card is inserted and the option made available? Then try selecting the EE APN after swapping the SIM card. :):
Name - EE
APN - everywhere
IP Type - IPv4
Sign in Type - PAP
MMSC - http://mms/
MMS proxy - 149.254.201.135
MMS Port - 8080
MCC - 234
MNC - 30
Download the correct setting direct to your phone here.
Thanks,
