by Eur0star
APN setting for Windows 10 laptop
I have a Lenovo P52s laptop, using Windows 10.  It uses a Fibocom L850-GL WWAN.
What are the APN settings for this device.
Re: APN setting for Windows 10 laptop
Hi @Eur0star,
Welcome to the EE Community.
You can find the EE APN settings in EE APN Settings: Where to find them.
Hope this helps. 🙂
by Eur0star
Thanks, had seen this before.  They are the setups for mobiles.
But, no doubt will apply, in part, to Windows 10
e.g. what is the sign-in info - PAP, CHAP or MS-CHAP
and APN type internet and/or attach
Hi @Eur0star,
Can you try it with APN type as 'internet' and authentication type as 'CHAP' and let me know if that works?
