by Skilled Contributor
Skilled Contributor
A answer would be nice
This morning I did tweet ee & marc's twitter account but no ones bothered to reply. Can you explain why the SIM only plan offer 60 mbps downlaods? Where are the fastest tariffs ? https://shop.ee.co.uk/sim-only/pay-monthly-phones
16 REPLIES 16
by Brilliant Contributor
Re: A answer would be nice
Because it' a policy EE has taken. You will find they would rather you purchase a phone contract so most likely hold out for the fastest speed to the customers doing just that.
Skilled Contributor
I buy my phone's outright I don't want wish to buy a phone from them, period. I can't believe EE would only offer the fastest speed to those buying a unit from them. (I blinking hope not.)
What's happen to the roaming now in the USA etc which was previously offered in the MAx plans, I'm unable to see these listed anywhere?
Lee
by Profile closed
Not applicable
@leeuk I agree, the new EE SIM only plans are over-priced garbage.
It really is a case of 'what where EE thinking?' when they re-launched SIM only the other week
You can now 'conviently' pay an extra £2.00 a month for a 'go faster' add-on which gives you full speed 4G or pay a eye-watering £10 extra a month for the 'go further' add-on which gives you roaming in those 5 extra none-EU countries.
All I suggest people do is vote with their feet and switch networks or simply don't buy/upgrade to these plans.
I'll be keeping for old EE Max SIM only plan for the foreseeable future now and EE will not get another upgrade out of me until these plans change.
Hi @leeuk,
As @Profile closed said, you can add the Go Faster add-on to your plan which offers you uncapped 4G speeds.
If you ever need to contact us via Twitter, please use @EE. The team are here to help from 7am-9pm (weekends 8am-8pm).
Skilled Contributor
Thanks for that.
Where did you find this info?
plus theres an increase in March 😞
 i would rather they cut the sport crap which we are no doublt paying for -sadly that wont happen being Gavin and Marc and BIG sport fans.
I hate all this add on crap - i jsut wan tto choose a plan and pay for it.
Lee
Skilled Contributor
Im already on a max plan does this mean I have to pay another £2 per month and £10 for usa caoverage?
lee
No @leeuk, there won't be any changes to your existing Max plan.
Skilled Contributor
Thanks james for the confirmation.
lee
No problem @leeuk Smiley Happy
by Kelv1000 Investigator
How do you buy the go faster add on. Doesn't show in the app but the go further one does?
Hi @Kelv1000,
Welcome back to the community.
I'm sorry it's not showing in your app.
Please get in touch with customer services and a member of the team will be happy to add it for you.
@James_B: Where is the Help page on GO FASTER? I can find Go Further Roaming Add-on Help, but not that.
I can't find a help page either so I've sent a few emails to look into this @XRaySpeX.
Thanks 🙂
by Profile closed
Not applicable
Both add-ons are mentioned in the EE SIM only price plan:
Go Faster Add-on
Available with pay monthly EE SIM plans. Cost is £2 per month. UK use only. 4G speed is usually capped at 60MB on SIM plans; this Add-on allows you to access uncapped 4G speeds. You can only use mobile internet or make calls on our 4G network if you’re within a 4G-enabled area and in range of a 4G base station. You’ll need a 4G calling compatible phone to make and receive calls over our 4G network. Your 4G phone may not be compatible with other UK 4G networks. You can check your 3G and 4G coverage at ee.co.uk/coverage. The speeds you achieve will also depend on a number of factors including: your location, the device you are using and geographic factors such as tree coverage and population density. If you are using your phone indoors, the materials of the building you’re in may also affect mobile internet speeds. Access to our enhanced 4GEE speeds will also be impacted by the location of our masts and equipment optimised for enhanced 4GEE speeds. Such equipment is not available everywhere in the UK and so you should check your coverage at ee/co.uk/coverage before purchasing the Go Faster Add-on. Subject to credit check. Cost added to next bill and then every bill each month until you ask us to remove it.
Go Further Add-on
 Available with pay monthly EE SIM plans. Cost is £10 per month. 6 month minimum commitment required. This Add-on allows you to use your data allowance in the USA, Canada, Mexico, Australia and New Zealand in addition to the UK & EU/EEA. Data fair use policy may apply. See www.ee.co.uk/terms for countries and details. Deposit needed for roaming in limited circumstances. Subject to credit check. Cost added to next bill and then every bill each month for the 6 months minimum term (even if you terminate before the end of the 6 month minimum term). After 6 months it will continue each month until you ask us to remove it. Allowances last until next bill or until used up, whichever comes first. Allowances don’t roll over. Once you have used up the allowance, or if you have hit your fair use policy amount, standard rates apply as set out in the Non-Standard Price Guide.
Thanks, @Profile closed. Good find!
by jesere Investigator
Text GO FASTER to 150
