by Ethgeddes Contributor
800mhz
When will EE be bringing out 800mhz in city centres because it terrible that they advitise the best 4g coverage but compared to other networks it's terrible. EE need to get there prioritys right and instead of keep bringing out faster speeds bring better indoor coverage. I would rarther be on a network with better indoor coverage then speed because 20mbps is more then plenty for a mobile rarther then like 90mbps.
Re: 800mhz
EE are rolling out more frequencies across the country. If you are struggling indoors can you not use EE VOWIFI service?
Thanks,
