by aimeesteele1 Investigator
4g turns off when on a call. S6
Hi. I have a Samsung S6 and whenever I'm on a call my 4g disappears but I can connect to WiFi. Any solutions?
11 REPLIES 11
Re: 4g turns off when on a call. S6
@aimeesteele1  Are you a contract customer or PAYG customer?
by Skilled Contributor
Skilled Contributor
Is LTE/VoLTE on ?
http://devicehelp.o2.co.uk/samsung/g925f-galaxy-s6-edge-android-nougat/settings/how-to-activate-volt...
*Easiest way to find info is*
EE HELP SEARCH https://ee.co.uk/help/help-new
Phone +447953 966 250
Live Chat/Complaints https://ee.co.uk/help/help-new/make-a-complaint
Complaints Code of Practice https://ee.co.uk/help/help-new/safety-and-security/protecting-your-information/complaints-code-of-practice
I'm a SIM only contract customer
I haven't got that VoLTE option under the mobile networks???
Skilled Contributor
Was the S6 provided by a locked/network I assume ?
Skilled Contributor
Where the S6 was provided is the imperative part not the sim.
The S6 software would need VoLTE options - where/network did the S6 originate from ?
Skilled Contributor
It was from EE.
Skilled Contributor
Think you need to back up your phone to a computer and update phone software as S6 supports EE 4G Calling.
You are/must be on a earlier S6 software version.
Do this over WiFi (after backing up to a computer)
http://www.samsung.com/uk/support/mobile-devices/how-do-i-check-for-operating-system-updates-on-my-s...
Thanks. I will try this.
Skilled Contributor
No worries, hope it works as I know EE S6 was one of the few ‘WiFi Calling’ launch phones so I assume you’ve got software prior to launch.
Keep me updated 🙂
