Highlighted
by Investigator
4g router mobile wifi abroad
I am trying to connect in The Netherlands with my 4g mobile router
My devices have connected to the router but cannot access the internet. Signal is good.
Wifi light is blue, Network light is blue and flashing. Its using the Dutch KPN network
Can anyone help ?
Highlighted
Solution
Re: 4g router mobile wifi abroad
Hi @KAREN1211,
To activate a new SIM card, it must be connected to the EE network in the UK.
Unfortunately it isn't possible to activate a new SIM on a roaming network.
10 REPLIES 10
Highlighted
by Investigator
My 4g on the phone is working fine on the KPN network with a good signal but when I try and connect to the router I can't access the internet ???
Highlighted
Hi @KAREN1211,
Have you activated roaming in My EE?
Menu > Account Settings > Blocking > Roam Worldwide
Highlighted
by Investigator
Yes EU  roaming is on
Highlighted
Hi @KAREN1211,
Does your WiFi device show it has a network signal?
Highlighted
by Investigator
Hi
the network sign is on, flashing blue and I have 3 bars showing on the WiFi indicator
Highlighted
Hi @KAREN1211,
Is this a new device or have you used it before in the UK?
Highlighted
by Investigator
It’s the first time I have used it. Didn’t try it in the U.K. ?
Highlighted
Solution
Hi @KAREN1211,
Highlighted
by Investigator
Ok James, thank you so much for all your help, very much appreciated
Karen
Highlighted
No problem @KAREN1211
I'm sorry I couldn't help you activate your SIM.
