by ryanha Investigator
4g router into hub?
hi if i get the 4g antenna and router can i run an ethernet from the router into my network hub at home and 'share' the internet to my network ports in my house. Also im assuming the router is wireless anyway? if so what are the specs please?
Re: 4g router into hub?
For a rather brief spec see 4GEE Home Router . It doesn't mention it but it has 2 Ethernet LAN ports. More can be seen in the INTERACTIVE DEMO on 4GEE Router - getting started .
thanks for the response... but it that a yes?
It's the best "yes" to the specs you asked for that I can give.
As for connecting 2 routers having 2 WANs I have no experience. So I did not comment on that.
EE Employee
Hi @ryanha and welcome to the community.
The router is indeed Wireless, specifications can be found on our shop page.
I can certainly try and find out information in regards to the Ethernet query for you.
Many thanks,
Lee
by akenc Contributor
Yes you can.  I have 4GEE broadband and run one of the ethernet ports into a switch, then into a second router - my home network is behind that.
