by Mhdcharlie Investigator
4g not working
 I have a 4gEE SIM, but it does not provide me with 4g at all on my S7, does anyone know why?
Solution
Re: 4g not working
Hi @Mhdcharlie
Welcome to the community 🙂
Thanks for the help, @Schockwave and @Northerner
To make sure your 4G is switched on, please follow these steps:-
Tap Settings >>> Mobile Networks >>> Network Mode >>> 2G/3G/4G (auto)
Can you connect to data services using 2G/3G?
Chris 🙂
8 REPLIES 8
by Brilliant Contributor
Re: 4g not working
Hello @Mhdcharlie,
Welcome to the community,
4G will only work where you can get 4G, so if you are in an area where there is no 4G signal, you will not get it.
Re: 4g not working
Yes, but my family and friends are receiving 4g (they have a 4gEE SIM and we are in the same location)
Re: 4g not working
Is data active on  your phone?
Can  you download the settings from here to ensure the ones on your phone are correct.
Re: 4g not working
@northener how would I do that?
Solution
Re: 4g not working
Hi @Mhdcharlie
Chris 🙂
Re: 4g not working
@Christopher_G thank you, it turns out it was on WCDMA/GSM auto-connect not LTE/WCDMA/GSM auto-connect
Re: 4g not working
Fantastic, I'm glad that worked @Mhdcharlie. Thanks for getting back to me 🙂
I hope to see you around the community again in future.
Chris 🙂
Re: 4g not working
Thank you for coming back and letting us know @Mhdcharlie, glad you got it sorted.
