by SarahM0312 Investigator
4g not working
4g not working or 3G - any help
by Profile closed
Not applicable
Re: 4g not working
Hello @SarahM0312 sorry to hear you are having service problems. Have you restarted the phone? What phone do you have? Can you test it in another phone?
Here is a link containing the Network Status Checker where you can check your area for any faults or upgrades going on. :):
https://myaccount.ee.co.uk/networkchecker/checkservice
Re: 4g not working
Hello there @SarahM0312.
What device are you using?
How long has this been going on for?
Thanks, Leanne 🙂
by Ace Contributor
Re: 4g not working
Just to add on to the good advice @Profile closed has given.
But have you checked in your phone's settings, to see if "mobile data" has been switched off. Sometimes a software update can do weird things like this.
Also. I can remember in the past losing 4G (I know you can't get 3 or 4G) when there was carrier update.
Not sure what phone you have, but on an iPhone, if you go into Settings/General/About, if there is a carrier update available, going into here will trigger the prompt to update.
Also to check on an iPhone if mobile data is off. Go into Settings, you will then see Mobile Data on the next screen. Go into this and on the very next screen, right at the very top, you will see the switch to turn mobile data on or off.
