by AndrewB62 Contributor
4g mast in woolavington will be upgraded?
Hi does anyone know when this mast will be upgraded? as just had mobile home broadband installed only to be told the mast I’m connected to is old technology
thanks A
7 REPLIES 7
EE Employee
Re: 4g mast in woolavington will be upgraded?
Hi @AndrewB62 and welcome to the community.
So I can try and assist on what coverage you should be getting please may I take your postcode.
Many thanks,
Lee
by Star Contributor
Star Contributor
I have checked the sites surrounding Woolavington and they all appear to have 4G, nearest:
Puriton 61771 L08/L18
Knowle 92305 L18
EE Employee
Hi
my post code isTA7 9AR and when the engineers visited to install you new broadband Aeriel it is pointed at the knowle crancombe lane som0003 as this was the strongest signal and as the speed was quite slow they said it must be due an upgrade
thanks Andrew
Hi
by Star Contributor
Star Contributor
I will look into this some more tonight.
EE Employee
Hi @AndrewB62
I have sent you a private message to look further into this for you.
Many thanks,
Lee
