by ChrisSimpson Contributor
4g calling on the s10
4g calling is not working on my s10, EE said samsung don't support it and I need to wait for an update,  samsung support say it is supported.
Had anybody got am s10 that 4g calling/Volte  works on?
13 REPLIES 13
Re: 4g calling on the s10
Where did you buy this phone? What does it tell you when you dial *#1234# ?
by Brilliant Contributor
The S10 definitely supports it.
Do you get 4G for data?
Do you have the sim inserted sim 1 on the tray or sim 2?
It's direct from EE, simcard in tray 1
I do get 4g data, phone drops to 3g as soon as a call connects
Hi @ChrisSimpson
Can you provide the information @XRaySpeX  has asked for.
This service is only available on EE pay monthly customers. If this service is available on your handset it will be under Call - (settings) three dots - WiFi calling.
It's 4G Calling OP wants.
It is a pay monthly contract
Ah, good. That's EE firmware. 4G Calling should be available on it. Have you looked  under Settings / Connections / Mobile Networks for VoLTE Calls? Is it ticked? Can you tick it?
The option isn't there.  EE day its down to Samsung who says it's EE.
Just wondered if anybody actually had it working on an s10
Not there at all? Not even greyed-out?
Morning @ChrisSimpson
I would recommend speaking to our Tech Gurus again on 150, they will be able to get this looked into further for you.
Let us know how you get on.
Factory reset fixed the issue.
I reset and the volte icon initially appeared but disappeared whether I selected to restore backup.
Reset phone again without restoring backup and volte works, icon visible, receiving hd calls.
Hi @ChrisSimpson
Thanks for coming back and letting us know 🙂
