by jackbareau Investigator
4g and signal on I phone 8
My 4g and the general signal is no longer working on my i phone 8. Please, could someone advise me on how to fix this, thanks!
12 REPLIES 12
Re: 4g and signal on I phone 8
Have you checked the Network Status Checker  ?
Hi @jackbareau,
Welcome to the EE Community.
Did the Network Status Checker show any problems in your area?
Does your phone work OK in other places?
Yes, it states there is a service problem in our area. However, this hasn't affected any other members of my family are on ee; their 4g and signal are both working.
Thanks for letting me know @jackbareau
Have you been able to test your phone in another area to see if it's working?
yep, and the problem remains the same
@jackbareau  Have you tried a network reset on the device?  Go to Settings>General>Reset>Reset Network Settings.  You will need to put your WiFi passwords back on the device after this.
EE Employee
Hi @jackbareau
Is the handset your own or did you purchase second hand?
Many thanks,
Lee
It is my own.
EE Employee
Hi @jackbareau
Did the network reset mentioned by @Chris_B help at all?
Many thanks,
Lee
@jackbareau  Have you at any point had a different network SIM card in the device?
No, the network reset didn't work, and no it hasn't been changed. Should I go into a store and ask for guidance there?
EE Employee
Hi @jackbareau
Are you able to try and family members SIM in your phone?
Many thanks,
Lee
