by Biz88 Established Contributor
4g Republic of Ireland
Does anyone know if 4g roaming is avalible in Ireland? If so what network is used. Thanks
EE Employee
Solution
Re: 4g Republic of Ireland
Thanks @Chris_B
Hi @Biz88
Roaming on 4G is not currently available in Ireland.
You'll still be able to use your device for calls, texts and data.
You can see a list of places where 4G is available on the Roaming Help page.
Hope this helps!
Thanks - Karen. Smiley Happy
7 REPLIES 7
@Biz88 Yes roaming is available in Ireland as for the network you'll use can i ask why its not like you get a choice on it.
still perhaps @Karen_C or @James_B can help with that one
EE Employee
Solution
Thanks @Chris_B
Hi @Biz88
Hope this helps!
@Chris_B the reason I ask what network is used is because my family members I'm visiting live in a rural area and you can only receive signal from one provider.
@Karen_C Thanks Karen for your reply. Could you also confirm if hotspoting is included within the max plan abroad data allowance? Thanks
@Biz88  I've just done a quick google search and have found that the network EE use is the Meteor network.
@Chris_B Cheers Chris for finding that out for me.
EE Employee
No problem @Biz88
I've had a look through the T&C's and can't see any restrictions for tethering whilst abroad using the max plan data.
Recent solutions
