by snapper666
4g HS 1GB 7DA
Does anyone know what 4G HS 1GB 7DA is when it appears on a mobile phone bill as 'extra billing?'
I cant find a break-down option on the online bills to investigate what it means.
Thanks everyoneSmiley Happy
Solution
Re: 4g HS 1GB 7DA
@snapper666   Your daughter has purchased more data from EE .    It's 1GB that last for 7 days.
by Profile closed
Not applicable
Re: 4g HS 1GB 7DA
That is a 1GB 7 day data add-on you look to have purchased.
Did you standard data allowance run out this month and you then purchased some more data?
by snapper666
Re: 4g HS 1GB 7DA
Thanks for your reply, its my daughter phone and wondered why the bill is
high this month. Strange thing is, I'm the bill payer and she didn't mention
shed done this!
I wonder if it's a music download website?
Thank you!
Solution
Re: 4g HS 1GB 7DA
by snapper666
Re: 4g HS 1GB 7DA
Hi Chris,
Thank you, and yes, it appears that my daughter has replied to EE's kind
reminder that her data is about to run out, or has run out, to which they
give her the opportunity to, in just two clicks just buy more data.
I've now blocked this service on her phone so EE can't send her more
'opportunities'.
Thanks and Kind Regards.
