by Peter_O Contributor
4GEE Router Firmware Version
Good Morning
Could someone confirm what the latest firmware revision is for the 4GEE Router (HH70VB)?
Mine is showing HH70_E1_02.00_19
I have an email from EE back in June claiming a later version is available. I have never been able to download this update. Unit has been power cycled, reset, full master reset, danced around etc...
Cheers
Peter
17 REPLIES 17
Re: 4GEE Router Firmware Version
Hi @Peter_O
What happens when you check for updates?:
  1. Log into the Connection Manager by entering 192.168.1.1 in your website browser
  2. Login in using your username and password, if you haven’t login in before use the password Admin.
  3. Click on device settings
  4. Click on online updates and then "check for updates"
  5. The latest software version will then be displayed and available for download. This may take a few minutes.
Hi Chris
I get a message telling me my software is up to date. Hence the question about what the current released firmware version is?
Cheers
Peter
There is a later software update, @Peter_O.
We're aware of a small number of customers that have had problems receiving it and are working to get that resolved as soon as possible.
If you're experiencing problems with your service, I recommend getting in touch with technical support team.
Hi Chris
Thanks, but I think this discussion is now somewhat circular in nature. I have had three conversations with technical support. They can't even confirm firmware versions. The advice I received yesterday/confirmed today, suggested I take my router back to a local EE shop for replacement/repair.
Best Wishes.
Peter
That's unlikely to change anything. Hardware on sale in shops is usually behind the curve & the 1st thing they do upon power up is try & update themselves. It'll then be in the same position as your current device.
Well, that may be correct. However, this is the next step in the problem resolution approach. If/when it proves to be pointless, I can escalate further.
Cheers
Peter
Morning @Peter_O
Thanks for coming back to us.
If you speak to our technical support team they will be able to help you further.
Let us know how you get on.
Good Morning @Leanne_T
Many thanks for the advice, however, I have now had three conversations with your technical support team. Their advice is to take it back to an EE shop and request a replacement under warranty.
In none of my three conversations, nor via the community, has anyone yet been able to confirm the actual version  of firmware I should be running?
Keeping router firmware up to date is the absolute minimum effort that should be expected in terms of cybersecurity. Given that many users will not actively persue these updates it is worrying that there are likely to be a number of these devices out there running on old firmware. For the most part, most people will be blissfully unaware of this issue.
Best Wishes
Peter
Hi @Peter_O
If an update is not showing available and you're experiencing problems with your service as @Christopher_G has advised we will need to get this looked into.
Let us know how you get on after visiting an EE store.
Well. That was all a complete waste of time and appalling customer service.
Visited the local EE store who refused point blank to supply a spare unit. Their "excuse" was that their stock is entirely separate to the online stock from which my unit was supplied.
No amount of cajoling or persuasion that whatever EE's internal process issues that this was just poor customer service would change their mind. I had, in their words, been incorrectly advised by the onlibe/phone customer service and must take the matter up with them
To say I am unimpressed would be an understatement. If anyone has contacts at EE who can pick this one up from a customer perspective, I'd appreciate an introduction.
Cheers
Peter
Hi @Peter_O
I'm sorry to hear about your experience.
I've sent you a private message looking for some more information.
Please take a look and get back to me.
Hui @Christopher_G
Many thanks for the offline assistance and introduction. A replacement router should be arriving tomorrow. Let's see if this helps or it's a more widespread issue with firmare updates. Will post once installed/updated.
Cheers
Peter
Great news, @Peter_O
Let us know how you get on with the replacement router. 🙂
Good Evening @Christopher_G
Rwplacement router arrived, installed, same issue ;-(
The new router is on the same firmware version as my previous device - HH70_E1_02.00_19. Clicking on update results in a message telling me that my software is up to date.
Any thoughts what I should do with my spare 4GEE outer? 😉
Cheers
Peter
Hi @Peter_O
We're aware of a small number of customers that have had problems receiving the latest software version and are working to get that resolved as soon as possible.
Other than not being on the latest software, is there a problem with the device? Are you able to connect to the internet and use it normally?
by GR33User Investigator
I too am in exactly this same position having received yet another email to inform me to update.
Current version is HH70_E1_02.00_19 and my email says to update to version 14.2 !?
Reboot - no joy, Reset - no joy.
I am awaiting a call back having spoken to a 2nd line engineer who is seeking further advice and should be confirming the actual latest firmware version.
Hi Chris
100% of these routers that I am aware of (that's four in total) cannot be upgraded with the latest firmware. 100% doesn't seem like a "small number" to me. That said, of the four I am aware of three of them were supplied within a few weeks of each other. I guess that makes it possible that there's a production batch with the issue?
Keeping router firmware up to date is pretty much the minumum that should be expected. It would be good therefore if EE would publish data showing the real scale of the issue. I guess that would be somewhere between your "small number" and my "100% failure rate"?
Cheers
Peter
