by castlemaster Established Contributor
4GEE Home Router keeps powering off?
Hi there,
I have been more than happy with my 4GEE Home router since it arrived, well, until I had the external antenna fitted this week. Don't get me wrong, the antenna works perfectly, signal is 100% better, faster speeds etc.
The problem I have is that ever since it's been installed, every couple of days my router will just switch itself off, partially. It responds to pings but the web interface doesn't respond and it won't route any data. The led light is on the network port but the blue lights on the front of the unit are completely off.
Software version:
HH70_E1_02.00_18
Modem version:
HH70_E1_02.00_18
Any advice?
63 REPLIES 63
Re: 4GEE Home Router keeps powering off?
Hi @castlemaster
Thanks for coming to community 🙂
Is it switching itself off after a period of inactivity or is it just turning itself off in general?
Have you spoken to our technical team at all?
It may be worth a quick call into them to report this.
Cheers
Richard
I suspect innactivity, not spoken to tech team yet, need to get ready for an hour on the phone for that 😛
I think it will just be down to inactivity and power saving as well @castlemaster
Don't let anything get in the way of good Friday Fish and Chips 🙂
Richard
The 4GEE Home Router shouldn't need to power save as it doesn't have a battery but is run from the mains.
I imagine it is powersaving, but there are no options at all on the config to disable them, ssh'd in but couldnt' find any active logfiles either to see if there was some kind of power state logged in there.
I'll leave something pinging for the day to see if that stop sit powering down.
Please keep us updated @castlemaster
Cheers
Richard
Well I can confirm it stayed awake all night, so it's definitley something to do with the power saving settings on the device, clearly it goes into power saving but never wakes up.
I'll try again tonight with wifi on but no devices attached.
What power saving settings on the device? I thought you said there aren't any.
there are no power saving settings at all on the thing, not that you can see or change anyway
it seems I can ssh to the box and login, does anyone know where the configs are for busybox that I can check for power saving options?
OK last night left wifi on the box (I normally just have i off and use wired) but no devices connected, again this morning, no response from the box for routing or web, SSH works and I can ping it, the wifi light is on the box but no devices will connect to wifi.
Does anyone else have one of these boxes they can try the same with at all? (i.e leave all devices disconnected overnight) so we can establish if it's just a fault with my box?
Although I can SSH in, no signs of any logfiles in /var/log at all
Hi @castlemaster
Thanks for trying that.
I've sent you a private message to get some more information from you.
Please take a look and get back to me.
Thanks 🙂
Thanks Chris,
I'll reply to the PM now.
I wanted to leave it a few days just to be sure, but it seems the original unit I had must have been faulty as the replacement router doesn't powerdown now, so many thanks for a speedy replacement 🙂
Afternoon @castlemaster
Thanks for coming back to the community and letting us know.
Glad everything is working for you now 🙂
Have a lovely day.
Hmm, seems I spoke too soon.
The router has gone down twice since yesterday, infact once it did it in the middle of a speedtest and once again overnight, exactly same symptoms as before, no lights on top of router but responds to SSH but no reply at all on web and no routing at all.
EE Employee
Hi @castlemaster
Could I get you to disconnect the device from the external antenna and try it for 24hours so we can rule out the antenna causing your issues?
Many thanks,
Lee
OK i've just removed external antena (which is a shame as I'm now down to 1 or 0 bars 😞 ) and will leave it until it next exhibits same issue.
EE Employee
Hi @castlemaster
Try it for 24hours just to see if the antenna is causing any issues.
Many thanks,
Lee
