Highlighted
by Established Contributor
4GEE Essentials, 4GEE and 4GEE Max
I vaguely recall that there used to be plans that offered 3 4G plans.  Is that still the case?
Whatever is now offered, what are the headline benefits of each?
Highlighted
by Ace Contributor
Re: 4GEE Essentials, 4GEE and 4GEE Max
Hi @realtestman
EE currently offer two types of plans they are the EE Essential Plan and the EE Smart Plan
a full comparison can be found here
https://kenstechtips.com/index.php/ee-smart-plan-review
Thanks,
David.
Highlighted
by Ace Contributor
EE seem to have gone back to "up to 60mbps" on essential plans. I'm sure that wasn't there when the plans initially launched.
Highlighted
Hi @realtestman
You can see all of our available plans on our online shop.
A brilliant plus to the new plans is that you get swappable benefits which can be changed whenever you fancy it.
