by MarkPaton
New Member
4G
Hello
My phone says I have 4G but when I try and use my data to get on the internet it doesn't seem to work. I have checked on your app and it says I have good coverage in my area. Is there anything you can do to help?
King Regards
Mark
by Brilliant Contributor
Re: 4G
Have you checked the network status page there could be a fault in your area.
Re: 4G
Hi @MarkPaton
Depending on your device you can download your internet settings here.
Are you PAYG or pay monthly?
