by Milbobaggins Investigator
4G signal in Haydon End, Swindon
I get absolutely no signal whatsoever in my flat in Haydon End, Swindond and the signal is patchy at best in the surrounding area. Are there any plans to improve this or am I able to purchase a signal booster for my flat. Paying for a 60GB data plan and getting no service is pretty frustrating.
Ben
Re: 4G signal in Haydon End, Swindon
Hi @Milbobaggins.
Welcome to the community.
Have you checked your postcode in our Network Status Checker?
How long have you been experiencing this problem?
Jon
Hi Jon,
Thanks! I have checked the coverage and it says Haydon End is covered but obviously that's not entirely accurate. I moved here on the 12th and have had no signal at all in the apartment, but even if I go outside the signal sometimes doesn't come back.
Ben
Were there any maintenance works registered on the network status checker, @Milbobaggins?
No maintenance scheduled on the checker that I can see. I've reported the
problem though so hopefully they'll have a look at it.
Ben
Thanks for reporting it, @Milbobaggins.
Our technical support team will investigate it and send you any updates.
