by NickOnline Contributor
4G+ on tab s4 vs 4G lte on note 9
hi, i use wifi mostly when available out and about but find it slow most of the time.
I have upped my data alowance since getting the galaxy tab s4 and note9.
when looking at the connection i have noticed that the tab s4 gets 4G+ and is alot quicker than my note 9 which is always on 4g lte when i do a speedtest.
i was wondering why i can get 4g+ on the tab and only 4g lte on the note 9.
is it my contract or technlogy on the phone or somthing else ?
thanks
6 REPLIES 6
Re: 4G+ on tab s4 vs 4G lte on note 9
What EE plan is each device on? Could it be that the Tab S4 is on a Max Plan & the Note 9 isn't? Max Plans get EE's fastest 4G+.
Tab s4 is on tablet essentials
Note 9 is on anytime upgrade max
By that the tab should be 4g and note 9 4g+
But it's the other way round ?
Hi @NickOnline
I know you may have tried this before, but, could you try rebooting both devices and re-testing?
How much quicker is it? Could you post both speeds?
hi, reselts below but taken at home.  Again tabs4 on essentials plan is 4G+ and alot quicker than note 9 on anytime upgrade max plan.
thanks
Tablet below
note 9 below
Speed test below
note on left and tab on right.
Thanks for that @NickOnline
I really don't know what that would be.
I recommend speaking to our technical support team to see if they can offer any more insight into this.
Please let me know what they say.
I spoke to tech support online and they send out a new apn file I think it was.
I had to import it
Haven't noticed any difference yet tho so
I'm going to pop into a shop and show them the difference in speed on each device.
Will update when I've been in.
