by Pagemakers Established Contributor
4G+ on an iPhone
When connect to a 4G+ network what does the iPhone show? 4G or 4G+
Assuming the iPhone is of course 4+ compatible.
Solution
Re: 4G+ on an iPhone
@Pagemakers    The iPhone will only show 4G it will not show 4G+    And yes it is compatible.
Solution
Thanks very much
Hi @Pagemakers
I see @Chris_B has offered you a solution. 🙂
Find more information on EE coverage >
