Re: 4G+ on S10 Plus
Let us know how you get on after your next update @Tornado-Saq
by Tornado-Saq Valued Contributor
Valued Contributor
Re: 4G+ on S10 Plus
@James_B   I will do.  Apparently there is an issue with others too.  So, hopefully Samsung sort this soon.
Valued Contributor
Re: 4G+ on S10 Plus
HI Everyone.
Been in contact with Samsung and they have advised it is because the S10 Plus is not in the category for 4G+ speed.  Has to be Category 6 or above. (Cat 6 as they put it).
Find that very bizarre because technically my S9+ is quicker than the S10+.  How can an updated phone possible be like that?   Doesn't make any sense at all.
Re: 4G+ on S10 Plus
Hi @Tornado_Saq,
The Galaxy S10+ is a CAT 20 device.
by Ace Contributor
Re: 4G+ on S10 Plus
EE are disabling it from showing the +. They are now doing it on OnePlus phones by the looks of it too.  Whether they did it to stop people asking why they get 4G or 4G+ who knows, but now it means people ask why they never get 4g+.
Valued Contributor
Re: 4G+ on S10 Plus
@James_B   This just gets better and better LOL!!!   I'm on to Samsung Chat now just want to get this resolved.
@chistery   Is it just on this handset or all because I am still getting 4G+ on my S9 Plus and on my Galaxy Tab S4???
I am just wondering whether I am getting the quickest speed anyway but it just doesn't show as 4G+. ??  Is there anyway of comparing speeds?
Valued Contributor
Re: 4G+ on S10 Plus
Update from above - the chat advisor is now saying the S10 Plus does support 4G+. !!!!
Shoot me somone.
by Ace Contributor
Re: 4G+ on S10 Plus
Yep, it's a modern flagship.
EE disable the 4G+ symbol on their phones but you'll still be getting it.
Please check *#0011# field test menu to see the field test configuration.
Valued Contributor
Re: 4G+ on S10 Plus
@Peter_C   Just on with EE now.
I would like to inform that if you're looking for the 4+ symbol on the device that probably not happen the reason is 4G+ & 4G stands for fourth generation mobile phone technology: a superfast, high capacity network which makes doing things on your phone seem instant. Overall means both are the same, our main concern is to make sure that our customers will get the 4G speed and at time if they are near the Mast area or in placed which is less in busy environment you may get that '+' symbol.
by Ace Contributor
Re: 4G+ on S10 Plus
They disable the symbol on their devices. It's quite understandable really as 4G+ does not equate to network experience-you can have 5 bars of 4G+ be slower than 2G for example so EE just outright disable devices with their ROM or customised from showing it. Example here: it's most definitely 4G+ from field test application (Network Signal Guru) but phone is just saying 4G.
Screenshot_20190605-101243.jpg340mbps "4G"
If I pop the SIM in one of my non EE phones, it says 4G+.
Valued Contributor
Re: 4G+ on S10 Plus
@Peter_C    Thanks for the above.
Not sure why, but feels slower when it doesn't show 4G+ or am I just focusing on it a bit too much?  Haha
Recent solutions
